Tempo
- By Canonical Observability
latest/stable | 51 | 01 Aug 2024 | |
latest/stable | 9 | 16 Feb 2024 | |
latest/candidate | 71 | 01 Aug 2024 | |
latest/candidate | 9 | 12 Dec 2023 | |
latest/beta | 75 | 01 Aug 2024 | |
latest/beta | 9 | 12 Dec 2023 | |
latest/edge | 80 | 02 Sep 2024 | |
latest/edge | 9 | 31 Jul 2023 |
juju deploy tempo-k8s --channel edge
This howto has been incorporated in the tempo docs.
In order to instrument a charm with tracing telemetry, you will need to:
- Set up a model with
cos-lite
juju add-model clite
juju deploy cos-lite --trust
See more: Charmhub |
cos-lite
- Deploy
tempo
tempo-k8s
- Integrate tempo with
cos-lite
jhack imatrix fill
See more:
jhack
, GitHub |jhack
>imatrix
>fill
Alternatively, you can integrate manually by:
juju integrate tempo:logging loki:logging
juju integrate tempo:ingress traefik:ingress
juju integrate grafana:grafana-source tempo:grafana-source
juju integrate prometheus:metrics-endpoint, tempo:metrics-endpoint
juju integrate grafana:grafana-dashboard, tempo:grafana-dashboard
juju integrate traefik:tracing, tempo:tracing
juju integrate prometheus:tracing, tempo:tracing
At some point there will be an overlay bundle to deploy cos-lite
+ tempo
and integrate them; see this PR to follow the progress on the overlay.
At this point you should have a working cos-lite
plus tempo
deployment; something like this:
- Fetch the
charm_tracing
and thetracing
libs:
charmcraft fetch-lib charms.tempo-k8s.v1.charm_tracing
charmcraft fetch-lib charms.tempo-k8s.v2.tracing
See more:
, Charmhub |tempo-k8s
> Libraries >charm-tracing
> Libraries >tracing
- Add opentelemetry exporter dependency used by
charm_tracing
to yourrequirements.txt
opentelemetry-exporter-otlp-proto-http>=1.21.0
- Add an integration with
tempo
# in charmcraft.yaml
provides:
tracing:
interface: tracing
limit: 1
See more: File
charmcraft.yaml
>provides
- Instrument your charm code:
# in /your/charm/project/src/charm.py
from charms.tempo_k8s.v1.charm_tracing import trace_charm
from charms.tempo_k8s.v2.tracing import TracingEndpointRequirer
@trace_charm(tracing_endpoint="tracing_endpoint")
class MyCharm(CharmBase):
def __init__(self, *args):
super().__init__(*args)
# add a provider wrapper for the tracing endpoint
self.tracing = TracingEndpointRequirer(self, protocols=["otlp_http"])
@property
def tracing_endpoint(self) -> Optional[str]:
"""Tempo endpoint for charm tracing."""
if self.tracing.is_ready():
return self.tracing.get_endpoint("otlp_http")
return None
By default, the traces generated by this charm will be tagged with service name equal to the class name of the charm, so "MyCharm"
in this case. You override this default by passing
service_name="foo"
to trace_charm
- Pack, deploy, and integrate your charm with
cos-lite
charmcraft pack
juju deploy ./my-charm-operator_ubuntu-20.04-amd64.charm mycharm \
$(yq eval '.resources | to_entries | map(select(.value.upstream-source != null) | "--resource " + .key + "=" + .value.upstream-source) | join(" ")' charmcraft.yaml)
juju integrate mycharm:tracing tempo-k8s:tracing
cos-lite
is a kubernetes bundle. tempo
is a Kubernetes charm.
See more:
charmcraft pack
, Juju |juju deploy
, Juju |juju integrate
- View the traces for the charm.
Open the Grafana dashboard in a browser (see here for more detailed instructions).
Next, navigate to the traces for your charm:
- go to
Explore
and select the Tempo datasource. - pick the
service_name
you gave to MyCharm above (the default is the application name) to see the traces for that charm - click on a trace ID to visualize it. For example, this is the trace for an
update-status
event on the Tempo charm itself:
Mapping events to traces with jhack tail
jhack tail
supports a -t
option to show the trace IDs associated with a charm execution:
This means that you can tail a charm, grab the trace id from tail, put it in the grafana dashboard query and get to the trace in no time.
